RUT901 Send SMS with Verizon
I have an RUT901 that was bought to test sending SMS for our building management system. I see from other posts that Teltonika does not like Verizon sims and there is supposed to be a workaround using - gsmctl -A ‘AT+QCFG=“ltesms/format”,1’
When I run this command I get +CME ERROS: operation not supported.
Could you please try using the command gsmctl -A 'AT+QCFG="sms/format",1' and let me know if the error persists?
We apologize for any inconvenience, but unfortunately, the EC200A module in the RUT901 is not compatible with Verizon due to band and certification limitations.
