Rut901 comands at
Previously, the command was accepted, now it shows me the error on devices rut200, rut901.
How can I carry out this command, it is for testing.
Could you please specify the current internal modem firmware version on your RUT901?
Test with the most recent version and it won’t let me write: RUT9M_R_00.07.03.1
Also perform tests with the lowest version: RUT9M_R_00.07.09
devices like rut950, rut240, rutx11, rutx12 if they let me apply the command to overwrite the IMEI I need to enable it to be able to carry out my tests.
I look forward to your response
Internal modem firmware version??
Could you please provide the internal modem firmware version? You can find it in the WebUI by navigating to System → Firmware → Update Firmware, next to Internal modem firmware version.
yes of course
first images will be with the version below and the new version
with the new version it doesn’t let me place the command either
IMEI chaning is not a legal thing, in my opinion. Interesting testings…
Thank you for providing all the information. I have forwarded this to our R&D team and will get back to you as soon as I receive their feedback.
Yes, the change can be made in later versions and it is not illegal. If you misuse it, it may be so.
thank you very much I await your response
According to Quectel, the command was never officially disclosed to customers and should not be used, as it could violate laws in some countries. The ability to change the IMEI was planned to be removed or restricted, and it is likely that this change has already been implemented.
We appreciate your understanding.
thank you very much for the information
