RUT50X - WiFi Multi AP issues
Hi there!
I’m currently setting up a RUT50X with Firmware RUTX_R_00.07.07.1 for a local firebrigade.
The car in which that RUT is used is moving around for emergency cases.
In some areas there are WiFi Connections as a WAN available. As this are different networks with different SSIDs I need to use the Multi AP Feature.
In some areas there are multiple access points providing signal with the same SSID for greater coverage.
If I just configure a single client then i get connection to the one with the strongest signal.
If I use Multi AP then the RUT is selecting randomly an AP (BSSID) which mostly has weakest quality in signal strength.
Is this a bug?
Thanks,
Carsten
