If I’m powering the unit with the supplied adapter, which is plugged into a neutral bonded receptacle, do I need to use the earth ground screw and a bare wire to earth ground (the receptacle box) or is the unit earthed via the negative lead of the supplied adaptor? I have an antenna outside so I want to make sure the unit is sufficiently grounded
The RUTM50 unit is not grounded through the power supply’s negative terminal. To properly ground the unit, a dedicated ground wire should be attached to the grounding screw on the device’s housing and connected to a reliable earth ground point.
Let me know if you have any further questions.
