RUT36X_R_00.07.04.3 openvpn
Hi
With a pc connected to the internet, I would like to join the lan network of a rut360.
I have installed Openvpn server on the rut. The staut is active.
Here is the router conf:
Enable : on
Enable OpenVPN config from file : off
TUN/TAP : TUN (tunnel)
Protocol : UDP
*Port :1194 *
LZO : None
Authentication : TLS
Encryption : AES-256-GCM 256
TLS cipher : All
Client to client : Off
Keep alive : 10 120
Virtual network IP address : 172.16.50.0
Virtual network netmask : 255.255.255.0
Push option :
Allow duplicate certificates : off
Authentication algorithm : SHA1
Additional HMAC authentication : None
Use PKCS #12 format : off
Certificate files from device : off
Certificate authority : ca.crt (1.2 KB)
Server certificate : server.crt (4.6 KB)
Server key : server.key (1.7 KB)
Diffie Hellman parameters
On the RUT, how do I create a user with a password?
On my computer, I need to import an ovpn file.
How do I generate this file?
Thank you
Sincerely
In your case, I would suggest looking at our OpenVPN configuration examples here and here. The first one shows how to configure an OpenVPN client on a Windows machine. The second article provides more information on the OpenVPN configurations.
