RUT361 remote access
I have set up a Remote Acess on a RUT361
I can access the devises connected to the RUT361 with the link generated by the remote management system but that link is only valid for a short time.
How can a make a link that will be acive for ever to give to the customer that wants to monitor his devices ?
I see no possibility to do that or to use use dyndns or smillar on the RUT361 ?
Thank you for reaching out.
To provide your customer with a longer valid remote connection link via the Remote Management System (RMS), you can easily extend the link’s active duration by selecting a larger “Duration time” period. This option allows you to set the link validity for a much longer time than the default setting.
Please refer to the screenshot below to see where the “Duration time” setting is located in the RMS interface.
Select a longer duration period and click “Generate” to create the link. This will give you a remote connection link with a significantly extended validity compared to the default 45 minutes.
Let me know if you need further assistance or have any additional questions. I’m here to help!
Thanks a lot, now I noticed that :smile:
You’re very welcome!
If you have any other questions or need further assistance, feel free to reach out anytime.
