RUT360 pin stuck inside SMA connector
What is the part number of the SMA connector used in the RUT360 router?
I can’t use one of the two connector, because of the antenna pin stuck in it…
Rafal
Photo of the connector:
Thanks for reaching us, Please verify if the product number you’re seeking is PR1US440 for SMA.
Is PR1US440 the product number you are searching for?
Thanks,
Hello and thank you for your answer.
To clarify - I need the part number of the connector soldered to PCB to replace it, not the antenna part number.
I found very simmilar Amphenol 132372 - but I compared dimensions and this is not it…
Rafal
Thank you for providing clarification; currently, we do not possess the part number for the connector that is soldered to the PCB.
Thanks,
Mahmoud
