I am trying to install nmap package and can not do it because of lack of space.
What could be the solution? I assume there is an option to delete some packages? What packages could be safely deleted then? E.g I see plenty of vuci packages installed, which I assume are kind of UI-related packages. Can I delete them?
root@RUT360:/tmp# opkg -e /etc/opkg/openwrt/distfeeds.conf install nmap
Installing nmap (7.80-3) to root...
Package installation encountered an error, removing previously installed packages.
Collected errors:
* verify_pkg_installable: Only have 172kb available on filesystem /overlay, pkg nmap needs 2169
root@RUT360:/tmp# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 9.7M 9.7M 0 100% /rom
tmpfs 60.8M 4.1M 56.7M 7% /tmp
/dev/mtdblock6 3.8M 3.6M 176.0K 95% /overlay
overlayfs:/overlay 3.8M 3.6M 176.0K 95% /
/dev/mtdblock7 576.0K 240.0K 336.0K 42% /log
tmpfs 512.0K 0 512.0K 0% /dev
