RUT360 inadequate Mobile Usage data [bug]
Firmware Version: [RUT36X_R_00.07.06.3]
on the page: [Status]> [Realtime Data]>[Mobile Usage]
the page WEEK only shows three days
the page MONTH only shows three days
the page TOTAL shows days without mobile usage even though there was usage
I apologize for any inconvenience caused by this issue, our developers are already aware of it and working on a fix. The issue you’re encountering is planned to be fixed in the upcoming firmware versions (most likely 7.7).
As a temporary solution, you can address the bug by configuring your browser to use the European date format (dd-mm). Additionally, you may consider resetting your RUT360 through the bootloader menu (this process will erase mobile usage data). Detailed instructions on how to perform a reset can be found on our wiki page: RUT360 Device Recovery Options - Teltonika Networks Wiki
Marija
