RUT301. Create and execute C code
Is it possible, using the C programming language, to obtain information through the MQTT protocol, encapsulate it in a frame, and finally transmit it through a TCP/IP port available in the RUT301?
I have my own device with TCP/IP communication and a particular protocol. I would like to use the RUT301 router to act as an MQTT gateway to the device’s own protocol. That’s why I need to be able to program and execute a small code in C.
I hope I have expressed myself clearly,
Thank you.
