RUT300 SFTP Upload Failure
Dear all,
I have been using different RUT300 for several projects and they all always worked quite well. However today during the upload a file via SFTP on the UI it communicated it uploaded it successfully, however when accessing the device via SSH the file was not present.
What could be the cause of this issue ?
Thanks a lot in advance for your help :slight_smile:
You mentioned that it was working fine before. What changed? Maybe there was some configuration or network changes? Maybe you updated the firmware?
Also, does the issue replicate or did it happen only once?
Since it communicated that the upload was successful, is it possible that you accidentally uploaded the file to a different directory?
