Hello ,
There is a tutorial for Layer 2 Access i.e. DCP and LLDP ? We use the latest firmware.
We need it for Siemens TIA Portal discovery.
Thank you!
Thank you for reaching out and welcome to the Teltonika Community!
To use LLDP on Teltonika devices, an LLDP-compliant device is required. Currently, TSW202 and TSW212 are the only models that support LLDP.
To enable LLDP, please follow these steps:
- Connect to the TSW device.
- Access its WebUI.
- Navigate to Services > LLDP and enable the service.
By default, all ports are configured to support LLDP, so enabling the service is sufficient. However, if you need to disable LLDP on specific interfaces, simply select the desired interface and click Disable.
To view LLDP neighbors, scroll down to the LLDP Neighbors section, where you can see connected devices and relevant details. Additionally, you can adjust the Interval setting, which defines how frequently network updates occur (measured in seconds).
For more details, please refer to our wiki: TSW202 LLDP – Teltonika Networks Wiki
Regarding DCP, it is a key component of the Profinet protocol, which is also supported on TSW202 and TSW212. Could you please specify what information you need about DCP?
For more details on Profinet, please visit: TSW212 Profinet – Teltonika Networks Wiki
If you have any further questions, feel free to reach out.
Kacper
