Hello!
I started to use a Teltonika RUT260 a couple of days ago:
- Device: Teltonika RUT260
- Product Code: RUT26000XXXX
- Batch No.: 2
- Hardware revision: 1
- Firmware version: RUT2M_R_00.07.07.3
- Kernel version: 5.15.149
After a restart everything works fine, but every couple of hours the router loses internet connection and does not reconnect.
This is what I checked so far:
- The administration panel says “connected”
- Checked the logs dozens of times, nothing suspicous to see there (at least for me)
- Updated to the latest firmware
- Created troubleshoot files after a restart and after I noticed the internet connection was not working anymore
- Both antennas are properly connected to the device
- It makes no difference if I connect via wifi or cable
Connection resets do not help. I have to reboot the device, otherwise it will not reconnect. I tried to check the troubleshoot files, but I am not able to understand these files or do not know where to search for a solution.
If you could help me out here, e.g. by checking the troubleshoot files, I would greatly appreciate it. Is it okay to upload my troubleshoot files to this topic or should they be shared via personal message?
Thanks in advance!
