Refer to previous issue no. 14284. Router replaced. Setup went well and rms hub established and could communicate with it. Suddenly hub stopped working and nothing I could do would get it to go again. Did a factory reset and after the reset when the login was activated got the message “ invalid username or password” Went into bootloader mode and installed firmware version 7-04 and error message became “unit not reachable” Downloaded firmware 7-16.03 with same results multiple times. Last time error message reverted to “invalid username or password.
| Event | Status code | Created at |
| Device is temporarily blocked. | 17 | 2025-08-18 11:06:55 |
| Failed to verify device. | 113 | 2025-08-18 11:06:50 |
| The device is redirected to the authentication system. | 20 | 2025-08-18 11:06:46 |
| Device is temporarily blocked. | 17 | 2025-08-18 10:06:44 |
| Failed to verify device. | 113 | 2025-08-18 10:06:38 |
| The device is redirected to the authentication system. | 20 | 2025-08-18 10:06:35 |
| Device is temporarily blocked. | 17 | 2025-08-18 09:06:31 |
| Failed to verify device. | 113 | 2025-08-18 09:06:25 |
| The device is redirected to the authentication system. | 20 | 2025-08-18 09:06:20 |
| Device is temporarily blocked. | 17 | 2025-08-18 08:06:18 |
| Failed to verify device. | 113 | 2025-08-18 08:06:13 |
| The device is redirected to the authentication system. | 0 | 2025-08-18 08:06:06 |
| Device is temporarily blocked. | 17 | 2025-08-18 07:06:04 |
| Failed to verify device. | 113 | 2025-08-18 07:05:59 |
| The device is redirected to the authentication system. | 20 | 2025-08-18 07:05:53 |
| Device is temporarily blocked. | 17 | 2025-08-18 06:05:51 |
| Failed to verify device. | 113 | 2025-08-18 06:05:46 |
| The device is redirected to the authentication system. | 20 | 2025-08-18 06:05:40 |
| Device is temporarily blocked. | 17 | 2025-08-18 05:05:39 |
| Failed to verify device. | 113 | 2025-08-18 05:05:33 |
| The device is redirected to the authentication system. | 20 | 2025-08-18 05:05:28 |
| Device is temporarily blocked. | 17 | 2025-08-18 04:05:25 |
| Failed to verify device. | 113 | 2025-08-18 04:05:20 |
| The device is redirected to the authentication system. | 20 | 2025-08-18 04:05:15 |
| Device is temporarily blocked. | 17 | 2025-08-18 03:05:13 |
| Failed to verify device. | 113 | 2025-08-18 03:05:07 |
| The device is redirected to the authentication system. | 0 | 2025-08-18 03:05:01 |
| Device is temporarily blocked. | 17 | 2025-08-18 02:05:00 |
Any suggestions???
