Rut241 wan interface data use issue
I have a Rut241 installed in a van with the latest firmware installed. I’ve set up 2 wan interfaces, home WiFi and mobile. Failover and wan interface priority has also been set up so that the router uses the faster WiFi wan when it’s available. Have also set the WiFi wan interface to flush any other connections when that is available.
Everything is working fine, except when mobile phones connect to the router they use the mobile data connection rather than the WiFi wan even though it’s available. A wireless laptop, or wired lan device will use the WiFi wan connection as intended. Have verified this by observing the data use and speeds on the wan interface page. Obviously the phones will use WiFi wan when I switch mobile off.
Can anyone throw any light on this? Might it be an issue with the phones?
Tia
