RUT241 - using 2 RUT241 as transparent wifi bridge from LAN to a device
Is it possible to use 2x RUT241 as transparent wifi bridge to connect a device via wifi to an existing ethernet switch in a way the device behaves like being directly plugged to the switch?
Did anyone ever tried this setup? Is this done via Bridge- oder Forward-mode ?
