RUT241 routing through subnet
Hi
I am trying to route to subnet located behind a RUT241 inside one of my local networks. It looks something like this
I have set up a static route in the ASUS router to the RUT241 router as follows (WAN port of RUT241 on 10.1.1.10) .
At first this didn’t work at all, but i added a firewall rule in the RUT241 to handle forwarding as follows.
The only other thing i enabled was http(s) and SSH connection to the RUT241 on the WAN port.
Once this was set up i could ping the devices on the RUT241 subnet.
However nothing else worked. SSH, VNC connections weren’t getting through. SSH gave connection refused and VNC times out.
Are there other settings that have to be enabled to allow the route forwarding to work?
