RUT241 Remote monitoring capabilities
I’m looking for a way to have a regular report of devices active on the network behind a RUT241.
My first idea was to send log of DHCP to a remote syslog: I found no syslog capability, I’m not even sure I can get a list of DHCP clients.
Any idea?
You can get the list of DHCP clients in this file /tmp/dhcp.leases but sending it to a remote syslog server would require a scripting.
#!/bin/sh
# Specify the path to your .txt file
file_path="/tmp/dhcp.leases"
# Read the content of the .txt file
file_content=$(cat "$file_path")
# Send the content to the syslog server using the logger command
logger "$file_content"
# Optionally, you can add a custom tag and specify the syslog facility like this:
# logger -t "DHCP leases" -p user.notice "$file_content"
echo "File content sent to syslog server."
Mainly this script will just print the contents of dhcp.leases on your syslog :slight_smile:
I hope it helps
Thank you!
