RUT241, Private apn and internet conniction for RMS throught VPN
I’m having trouble getting RUT241 to connect to the Teltonika RMS service. The router is connected to private APN network and has no connection to internet.
I was wandering if it was possible to use VPN server or Proxy server on our internal network to still get internet access and to use the RMS service to remotely maintain multiple routers.
Thank you for reaching out regarding your RUT241 and the connection to the Teltonika RMS service. I understand that your router is connected to a private APN without direct internet access.
For the RMS to work you will need to contact your private APN provider to open specific ports and allow connections to RMS IPs.
More information about what ports and IPs should be opened for all the specific RMS functions to work here: What IP addresses and ports are used by RMS? - Teltonika Networks Wiki
