RUT241 OpenVPN client failing connect to server v.2.6.10
RUT241 with firmware RUT2M_R_00.07.06.6 not connecting to the server with version v2.6.10.
log is giving these messages:
Wed Mar 20 17:44:50 2024 daemon.notice openvpn(SeVPN)[26236]: AUTH: Received control message: AUTH_FAILED,Client incompatible with this server. Keying Material Exporters (RFC 5705) support missing. Upgrade to a client that supports this feature (OpenVPN 2.6.0+).
Wed Mar 20 17:44:50 2024 daemon.notice openvpn(SeVPN)[26236]: SIGTERM received, sending exit notification to peer
is any workaround for this ? RUTOS is using version 2.5.3
Currently, there is no workaround available as the server requires clients to upgrade to OpenVPN 2.6.0. However, this feature is already being worked on and should be available with the upcoming firmware release.
Marijus
