Hi There: I have a remote RUT241 that has stopped working for GUI login, it renders the login page when entering a correct username and password it just returns to the login screen (if incorect password it response as such).It had been working previously . Logging in via SSH works ok. I have rebooted via SSH but the problem remains Firmware RUT2M_R_00.07.10.4. It is remote and cannot be readily accessed for a cold powercycle or replacement. Any ideas how to resolve ? Many thanks
Could you please clarify how are you accessing the device? Are you connecting via VPN (and if so, which VPN protocol are you using), RMS or a public IP?
Have you tried accessing the WebUI using a different browser or an incognito/private window?
Did you make any configuration changes before the issue started occurring?
Please try restarting the web service by running the following command in the CLI:
/etc/init.d/uhttpd restart
Additionally, could you provide the output of this command:
df -h
You can also run the following command in the CLI:
logread -f
Then attempt to log in through the WebUI and check what logs appear. Do you see a message stating User “admin” successfully authenticated on HTTPS?
Thanks for the reply - here are details and logs from SSH.
not VPN
public ip
yes firefox and edge - also cleared cookies
i tried different computer and checked for ip blocks
No changes
No change
df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 9.9M 9.9M 0 100% /rom
tmpfs 60.6M 572.0K 60.1M 1% /tmp
/dev/mtdblock6 3.4M 704.0K 2.8M 20% /overlay
overlayfs:/overlay 3.4M 704.0K 2.8M 20% /
/dev/mtdblock7 576.0K 284.0K 292.0K 49% /log
tmpfs 512.0K 0 512.0K 0% /dev
logread -f
logread -f
Wed Apr 8 11:43:17 2026 kern.notice Password auth succeeded for admin on HTTP from 27.33.47.186
Wed Apr 8 11:43:17 2026 daemon.err uhttpd[11583]: vuci: accepted login for admin from 27.33.47.186
yes messages pasted above.
advice appreciated.
Justinas - I havnt heard back from the info I posted re diagnositic information you ask for - thx
Could you please clarify whether you still require assistance or if the issue has already been resolved?
