Доброго времени суток! Проблема такая, хочу поменять настройки VPN, но на веб страницу нету доступа (нету подключения) через SSH роутер не отвечает.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 18702.
