RUT240 - Shutdown completly until power removal
The RUT240 was installed and put online yesterday (2023-12-04 19h00). Around 5h00 a.m this morning he completely shutdown is it a power outage… I can’t confirm. The RUT240 is powered by a UPS and there’s an emergency generator on-site. It shouldn’t miss power.
The RUT240 never came back online until I arrive onsite. All light were off, I can’t reach/connect, no life sign. I’ve unplug the 120V connector on the RUT240 wait 1 minute and plug it back. The unit simply boot and everything works.
The system log file :
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.090353] pinctrl core: initialized pinctrl subsystem
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.098096] NET: Registered protocol family 16
Tue Dec 5 05:00:07 2023 kern.warn kernel: [ 0.144510] workqueue: max_active 576 requested for napi_workq is out of range, clamping between 1 and 512
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.158866] clocksource: Switched to clocksource MIPS
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.164414] NET: Registered protocol family 2
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.167851] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.176016] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.183071] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.190619] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.197654] TCP: Hash tables configured (established 1024 bind 1024)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.204228] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.210581] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.217943] NET: Registered protocol family 1
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.221882] PCI: CLS 0 bytes, default 32
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.232246] workingset: timestamp_bits=30 max_order=14 bucket_order=0
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.247999] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.252446] squashfs: patched 4.0 (2020/11/10) Oever Gonzalez
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.258132] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.288999] pinctrl-single 18040028.pinmux: 64 pins, size 8
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.294246] gpio-export gpio-export: 2 gpio(s) exported
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.318762] spi-nor spi0.0: w25q128 (16384 Kbytes)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.322204] 5 fixed-partitions partitions found on MTD device spi0.0
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.328469] Creating 5 MTD partitions on “spi0.0”:
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.333265] 0x000000000000-0x000000020000 : “u-boot”
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.339943] 0x000000020000-0x000000030000 : “config”
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.345045] 0x000000030000-0x000000040000 : “art”
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.349901] 0x000000040000-0x000000f70000 : “firmware”
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.361145] 2 tplink-fw partitions found on MTD device firmware
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.365697] Creating 2 MTD partitions on “firmware”:
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.370609] 0x000000000000-0x00000018bc8b : “kernel”
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.377163] 0x00000018bc8c-0x000000f30000 : “rootfs”
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.382202] mtd: device 5 (rootfs) set to be root filesystem
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.389646] 1 squashfs-split partitions found on MTD device rootfs
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.394477] 0x000000ab0000-0x000000f30000 : “rootfs_data”
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 0.401335] 0x000000f70000-0x000001000000 : “event-log”
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.407321] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.413667] 18020000.uart: ttyATH0 at MMIO 0x18020000 (irq = 9, base_baud = 2500000) is a AR933X UART
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.421647] printk: console [ttyATH0] enabled
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 0.430140] printk: bootconsole [early0] disabled
Tue Dec 5 05:00:07 2023 kern.err kernel: [ 0.796013] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.435711] switch0: Atheros AR724X/AR933X built-in rev. 2 switch registered on mdio.0
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.477464] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.486184] eth0: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.491492] i2c /dev entries driver
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.500141] NET: Registered protocol family 10
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.515869] Segment Routing with IPv6
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.518284] NET: Registered protocol family 17
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.523286] 8021q: 802.1Q VLAN Support v1.8
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.844580] ag71xx 19000000.eth: connected to PHY at mdio.0:1f:04 [uid=004dd041, driver=Generic PHY]
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.853973] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.868625] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.884839] Freeing unused kernel memory: 1204K
Tue Dec 5 05:00:07 2023 kern.warn kernel: [ 1.887951] This architecture does not have kernel memory protection.
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 1.894351] Run /sbin/init as init process
Tue Dec 5 05:00:07 2023 user.info kernel: [ 2.612728] init: Console is alive
Tue Dec 5 05:00:07 2023 user.info kernel: [ 2.615239] init: - watchdog -
Tue Dec 5 05:00:07 2023 user.info kernel: [ 4.949823] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.170676] usbcore: registered new interface driver usbfs
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.174941] usbcore: registered new interface driver hub
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.180216] usbcore: registered new device driver usb
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.200881] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Tue Dec 5 05:00:07 2023 kern.warn kernel: [ 5.219611] chipidea-usb2 1b000000.usb: 1b000000.usb supply vbus not found, using dummy regulator
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.230331] ci_hdrc ci_hdrc.0: EHCI Host Controller
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.233881] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.254885] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.260319] hub 1-0:1.0: USB hub found
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 5.263485] hub 1-0:1.0: 1 port detected
Tue Dec 5 05:00:07 2023 user.info kernel: [ 5.270039] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Tue Dec 5 05:00:07 2023 user.info kernel: [ 5.286585] init: - preinit -
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 7.296686] random: jshn: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 7.419944] random: jshn: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 7.689546] jffs2: notice: (558) jffs2_build_xattr_subsystem: complete building xattr subsystem, 32 of xdatum (19 unchecked, 13 orphan) and 41 of xref (12 dead, 1 orphan) found.
Tue Dec 5 05:00:07 2023 user.info kernel: [ 7.706451] mount_root: switching to jffs2 overlay
Tue Dec 5 05:00:07 2023 kern.warn kernel: [ 7.714179] overlayfs: upper fs does not support tmpfile.
Tue Dec 5 05:00:07 2023 user.warn kernel: [ 7.731174] urandom-seed: Seeding with /etc/urandom.seed
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 7.928782] random: mctl: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 8.638887] usb 1-1: new high-speed USB device number 2 using ci_hdrc
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 8.839268] random: procd: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 user.info kernel: [ 9.485977] procd: - early -
Tue Dec 5 05:00:07 2023 user.info kernel: [ 9.487691] procd: - watchdog -
Tue Dec 5 05:00:07 2023 user.info kernel: [ 10.193453] procd: - watchdog -
Tue Dec 5 05:00:07 2023 user.info kernel: [ 10.197398] procd: - ubus -
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 10.293781] random: ubusd: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 10.301781] random: ubusd: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 10.308069] random: ubusd: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 user.info kernel: [ 10.320972] procd: - init -
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 11.387942] random: jshn: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 11.442655] random: ubusd: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 11.448190] random: ubus: uninitialized urandom read (4 bytes read)
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 12.811574] jffs2: notice: (719) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Tue Dec 5 05:00:07 2023 user.info kernel: [ 13.011620] urngd: v1.0.2 started.
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 13.635706] random: crng init done
Tue Dec 5 05:00:07 2023 kern.notice kernel: [ 13.637659] random: 24 urandom warning(s) missed due to ratelimiting
Tue Dec 5 05:00:07 2023 user.info kernel: [ 13.755575] kmodloader: loading kernel modules from /etc/modules.d/*
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 13.987792] NET: Registered protocol family 15
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 13.998614] Initializing XFRM netlink socket
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.007924] tun: Universal TUN/TAP device driver, 1.6
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.097784] l2tp_core: L2TP core driver, V2.0
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.113404] l2tp_netlink: L2TP netlink interface
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.126804] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.145552] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.161694] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.197827] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.206811] gre: GRE over IPv4 demultiplexor driver
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.215483] ip_gre: GRE over IPv4 tunneling driver
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.242814] ip6_gre: GRE over IPv6 tunneling driver
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.626712] usbcore: registered new interface driver cdc_wdm
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.654427] Loading modules backported from Linux version v5.10.68-0-g4d8524048a35
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 14.660640] Backport generated by backports.git v5.10.68-1-0-ga4f9ba32
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 15.119441] usbcore: registered new interface driver usbserial_generic
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 15.124729] usbserial: USB Serial support registered for generic
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 15.299537] xt_time: kernel timezone is -0000
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.406660] PPP generic driver version 2.4.2
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.413719] PPP MPPE Compression module registered
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.421227] NET: Registered protocol family 24
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.427963] PPTP driver version 0.8.5
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.441066] qmi_wwan 1-1:1.4: cdc-wdm0: USB WDM device
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.448804] qmi_wwan 1-1:1.4 wwan0: register ‘qmi_wwan’ at usb-ci_hdrc.0-1, WWAN/QMI device, 72:34:d0:b9:39:b7
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.457876] usbcore: registered new interface driver qmi_wwan
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.515832] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.522291] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.934043] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.948025] usbcore: registered new interface driver option
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.952372] usbserial: USB Serial support registered for GSM modem (1-port)
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.959801] option 1-1:1.0: GSM modem (1-port) converter detected
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.965678] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.972625] option 1-1:1.1: GSM modem (1-port) converter detected
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.978578] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.985473] option 1-1:1.2: GSM modem (1-port) converter detected
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.991408] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 16.998317] option 1-1:1.3: GSM modem (1-port) converter detected
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 17.004273] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
Tue Dec 5 05:00:07 2023 kern.debug kernel: [ 17.183693] ath: EEPROM regdomain sanitized
Tue Dec 5 05:00:07 2023 kern.debug kernel: [ 17.183714] ath: EEPROM regdomain: 0x64
Tue Dec 5 05:00:07 2023 kern.debug kernel: [ 17.183720] ath: EEPROM indicates we should expect a direct regpair map
Tue Dec 5 05:00:07 2023 kern.debug kernel: [ 17.183752] ath: Country alpha2 being used: 00
Tue Dec 5 05:00:07 2023 kern.debug kernel: [ 17.183758] ath: Regpair used: 0x64
Tue Dec 5 05:00:07 2023 kern.debug kernel: [ 17.197772] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
Tue Dec 5 05:00:07 2023 kern.info kernel: [ 17.201616] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Tue Dec 5 05:00:07 2023 user.info kernel: [ 17.239905] kmodloader: done loading kernel modules from /etc/modules.d/*
Tue Dec 5 05:00:10 2023 daemon.notice procd: /etc/rc.d/S07network: Failed to apply configuration for switch ‘switch0’
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: bonding
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: 8021ad
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: 8021q
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: macvlan
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: veth
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: bridge
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: Network device
Tue Dec 5 05:00:11 2023 user.notice : Added device handler type: tunnel
Tue Dec 5 05:00:14 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Tue Dec 5 05:00:14 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: Connected to system UBus
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: started, version 2.85 cachesize 150
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: UBus support enabled: connected to system bus
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: using only locally-known addresses for domain test
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: using only locally-known addresses for domain onion
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: using only locally-known addresses for domain localhost
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: using only locally-known addresses for domain invalid
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: using only locally-known addresses for domain bind
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: using only locally-known addresses for domain lan
Tue Dec 5 05:00:15 2023 daemon.warn dnsmasq[1703]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: read /etc/hosts - 4 addresses
Tue Dec 5 05:00:15 2023 daemon.info dnsmasq[1703]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Tue Dec 5 05:00:19 2023 daemon.notice wpa_supplicant[1759]: Successfully initialized wpa_supplicant
Tue Dec 5 05:00:21 2023 daemon.info gsmd[1872]: gsmd-ng init
Tue Dec 5 05:00:21 2023 daemon.info gsmd[1872]: gsmd-ng canary build git#ef0afca924
Tue Dec 5 05:00:21 2023 daemon.info gsmd[1872]: Log compression support: no
Tue Dec 5 05:00:21 2023 daemon.info gsmd[1872]: Baseband feature support: no
Tue Dec 5 05:00:21 2023 daemon.info gsmd[1872]: gsmd-ng running
Tue Dec 5 05:00:23 2023 user.notice /bin/trigger_vuci_routes_reload: vuci reload_routes triggered
Tue Dec 5 05:00:31 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 15 seconds of timeout
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘TELUS’
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “TELUS”
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “56005”, cell ID: “140159559”, technology: “E-UTRAN”
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “56005”, cell ID: “140159559”, technology: “E-UTRAN”
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “56005”, cell ID: “140159559”, technology: “E-UTRAN”
Tue Dec 5 05:00:32 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “10.207.250.161”
Tue Dec 5 05:00:36 2023 authpriv.warn dropbear[2290]: Failed loading /etc/dropbear/dropbear_rsa_host_key
Tue Dec 5 05:00:36 2023 authpriv.info dropbear[2290]: Not backgrounding
Tue Dec 5 05:00:41 2023 kern.info kernel: [ 56.422159] eth0: link up (1000Mbps/Full duplex)
Tue Dec 5 05:00:41 2023 kern.info kernel: [ 56.436067] br-lan: port 1(eth0) entered blocking state
Tue Dec 5 05:00:41 2023 kern.info kernel: [ 56.439944] br-lan: port 1(eth0) entered disabled state
Tue Dec 5 05:00:41 2023 kern.info kernel: [ 56.445625] device eth0 entered promiscuous mode
Tue Dec 5 05:00:41 2023 kern.info kernel: [ 56.490684] br-lan: port 1(eth0) entered blocking state
Tue Dec 5 05:00:41 2023 kern.info kernel: [ 56.494559] br-lan: port 1(eth0) entered forwarding state
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘lan’ is enabled
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘lan’ is setting up now
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘lan’ is now up
Tue Dec 5 05:00:41 2023 daemon.notice netifd: bridge ‘br-lan’ link is up
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘loopback’ is enabled
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘loopback’ is setting up now
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘loopback’ is now up
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘wan’ is enabled
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘wan6’ is enabled
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Network device ‘eth0’ link is up
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Network device ‘lo’ link is up
Tue Dec 5 05:00:41 2023 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Tue Dec 5 05:00:42 2023 kern.info kernel: [ 57.443949] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Tue Dec 5 05:00:43 2023 daemon.notice netifd: mob1s1a1 (2466): wwan[2466] Using wwan usb device on bus 1-1
Tue Dec 5 05:00:45 2023 daemon.notice netifd: mob1s1a1 (2466): wwan[2466] Using proto:qmi_wwan device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
Tue Dec 5 05:00:46 2023 kern.notice Port link state of port CPU/WiFi changed to UP
Tue Dec 5 05:00:46 2023 kern.notice Port speed for port CPU/WiFi changed to 1000 baseT
Tue Dec 5 05:00:46 2023 kern.notice Port link state of port LAN1 changed to UP
Tue Dec 5 05:00:46 2023 kern.notice Port speed for port LAN1 changed to 100 baseT
Tue Dec 5 05:00:47 2023 user.warn mwan3-hotplug[2458]: hotplug called on lan before mwan3 has been set up
Tue Dec 5 05:00:49 2023 user.info kernel: [ 64.040042] kmodloader: loading kernel modules from /etc/modules-late.d/*
Tue Dec 5 05:00:49 2023 user.info kernel: [ 64.123246] kmodloader: done loading kernel modules from /etc/modules-late.d/*
Tue Dec 5 05:00:49 2023 daemon.notice netifd: mob1s1a1 (2466): Using net device: wwan0
Tue Dec 5 05:00:50 2023 daemon.notice netifd: mob1s1a1 (2466): Informing driver of raw-ip for wwan0 …
Tue Dec 5 05:00:50 2023 kern.info kernel: [ 65.364398] qmi_wwan 1-1:1.4 wwan0: mode: raw IP
Tue Dec 5 05:00:50 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --link-layer-protocol raw-ip --ul-protocol disabled --dl-protocol disabled
Tue Dec 5 05:00:51 2023 daemon.notice netifd: mob1s1a1 (2466): Starting network mob1s1a1 using APN: m2m.telus.iot
Tue Dec 5 05:00:52 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,17 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn m2m.telus.iot --pdp-type ip
Tue Dec 5 05:00:55 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Tue Dec 5 05:00:56 2023 daemon.notice netifd: mob1s1a1 (2466): 17
Tue Dec 5 05:00:56 2023 daemon.notice netifd: mob1s1a1 (2466): cid4: 17
Tue Dec 5 05:00:56 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,17
Tue Dec 5 05:00:57 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,17 --start-network --apn m2m.telus.iot --profile 1 --auth-type
Tue Dec 5 05:00:57 2023 cron.err crond[3191]: crond (busybox 1.34.1) started, log level 5
Tue Dec 5 05:00:57 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Tue Dec 5 05:00:57 2023 daemon.notice netifd: mob1s1a1 (2466): pdh4: -2027016752
Tue Dec 5 05:00:57 2023 daemon.notice netifd: mob1s1a1 (2466): -2027016752
Tue Dec 5 05:00:58 2023 daemon.notice netifd: mob1s1a1 (2466): Setting up wwan0
Tue Dec 5 05:00:58 2023 daemon.notice netifd: mob1s1a1 (2466): Setting MTU: 1500 on wwan0
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[1703]: exiting on receipt of SIGTERM
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: Connected to system UBus
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: started, version 2.85 cachesize 150
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: UBus support enabled: connected to system bus
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq-dhcp[3257]: DHCP, IP range 192.168.1.100 – 192.168.1.150, lease time 12h
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain test
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain onion
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain localhost
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain invalid
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain bind
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain lan
Tue Dec 5 05:00:58 2023 daemon.warn dnsmasq[3257]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: read /etc/hosts - 4 addresses
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq[3257]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Dec 5 05:00:58 2023 daemon.info dnsmasq-dhcp[3257]: read /etc/ethers - 0 addresses
Tue Dec 5 05:00:59 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Tue Dec 5 05:00:59 2023 daemon.info dnsmasq[3257]: read /etc/hosts - 4 addresses
Tue Dec 5 05:00:59 2023 daemon.info dnsmasq[3257]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Dec 5 05:00:59 2023 daemon.info dnsmasq-dhcp[3257]: read /etc/ethers - 0 addresses
Tue Dec 5 05:00:59 2023 daemon.notice netifd: Network device ‘wwan0’ link is up
Tue Dec 5 05:00:59 2023 daemon.notice netifd: mob1s1a1 (2466): Setting up wwan0 V4 DCHP
Tue Dec 5 05:00:59 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Tue Dec 5 05:00:59 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Tue Dec 5 05:00:59 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Tue Dec 5 05:01:01 2023 daemon.notice netifd: mob1s1a1_4 (3374): udhcpc: started, v1.34.1
Tue Dec 5 05:01:01 2023 daemon.notice netifd: mob1s1a1_4 (3374): udhcpc: broadcasting discover
Tue Dec 5 05:01:02 2023 daemon.notice netifd: mob1s1a1_4 (3374): udhcpc: broadcasting select for XXXXXXXXXX, server XXXXXXXX
Tue Dec 5 05:01:02 2023 daemon.notice netifd: mob1s1a1_4 (3374): udhcpc: lease of XXXXXXXXXX obtained from XXXXXXXXX, lease time 7200
Tue Dec 5 05:01:03 2023 daemon.info mobifd: Auto APN is disabled on “mob1s1a1”. Skipping Ping To DNS functionality
Tue Dec 5 05:01:03 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain test
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain onion
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain localhost
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain invalid
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain bind
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: using only locally-known addresses for domain lan
Tue Dec 5 05:01:03 2023 daemon.info dnsmasq[3257]: using nameserver XXXXXXXXX#53
Tue Dec 5 05:01:04 2023 cron.err crond[3553]: crond (busybox 1.34.1) started, log level 5
Tue Dec 5 05:01:05 2023 user.warn mwan3-hotplug[3442]: hotplug called on loopback before mwan3 has been set up
Tue Dec 5 05:01:06 2023 daemon.err insmod: module is already loaded - arc4
Tue Dec 5 05:01:06 2023 daemon.err insmod: module is already loaded - sha1_generic
Tue Dec 5 05:01:06 2023 daemon.err insmod: module is already loaded - slhc
Tue Dec 5 05:01:06 2023 daemon.err insmod: module is already loaded - crc-ccitt
Tue Dec 5 05:01:06 2023 daemon.err insmod: module is already loaded - ppp_generic
Tue Dec 5 05:01:06 2023 daemon.err insmod: module is already loaded - ppp_async
Tue Dec 5 05:01:06 2023 daemon.err insmod: module is already loaded - ppp_mppe
Tue Dec 5 05:01:13 2023 user.warn mwan3-hotplug[3822]: hotplug called on mob1s1a1 before mwan3 has been set up
Tue Dec 5 05:01:16 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
Tue Dec 5 05:01:18 2023 daemon.warn openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: --cipher is not set. Previous OpenVPN version defaulted to XXXXX as fallback when cipher negotiation failed in this case. If you need this fallback please add ‘–data-ciphers-fallback BF-CBC’ to your configuration and/or add BF-CBC to --data-ciphers.
Tue Dec 5 05:01:18 2023 daemon.notice openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: OpenVPN 2.5.3 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Tue Dec 5 05:01:18 2023 daemon.notice openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: library versions: OpenSSL 1.1.1t 7 Feb 2023, LZO 2.10
Tue Dec 5 05:01:18 2023 daemon.warn openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Tue Dec 5 05:01:18 2023 daemon.notice openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: TCP/UDP: Preserving recently used remote address: [AF_INET]34.230.227.9:33022
Tue Dec 5 05:01:18 2023 daemon.notice openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: UDP link local: (not bound)
Tue Dec 5 05:01:18 2023 daemon.notice openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: UDP link remote: [AF_INET]34.230.227.9:33022
Tue Dec 5 05:01:22 2023 daemon.warn openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: WARNING: ‘link-mtu’ is used inconsistently, local=‘link-mtu 1541’, remote=‘link-mtu 1542’
Tue Dec 5 05:01:22 2023 daemon.warn openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: WARNING: ‘comp-lzo’ is present in remote config but missing in local config, remote=‘comp-lzo’
Tue Dec 5 05:01:22 2023 daemon.notice openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: [teltonika-vpn-mGwMbX3t1h1PyLp0] Peer Connection Initiated with [AF_INET]34.230.227.9:33022
Tue Dec 5 16:17:58 2023 daemon.notice openvpn(rms_mGwMbX3t1h1PyLp0)[4162]: TUN/TAP device tun_c_rms_mGwMb opened
Thanks for reaching us.
Could you please send us the datasheet for the UPS you’re using?
Are you using 120VDC or 120VAC ?
Please let us know
It’s a 120Vac Eaton 9SX1000 UPS.
As an OEM, we replicate the same configuration over and over… I know the configuration work on the 22 other devices already sold with our control panel using 7.04.5 firmware. I got random trouble with all last 6 units purchased using the 7.05.4 firmware. It’s either the firmware or the device. We are all replacing them. Unstable, loose power connector, loose ethernet connector and weird trouble with the Mobile connection…
This RUT240 device gives me so much trouble… I’ve decided to just replace the unit. Time is money… and I’ve lost so much time on these devices.
