RUT240 OpenVPN SIM Forward port
I spent the day trying to do Port Forwards, it doesn’t work. :frowning:
From a computer (192.168.19.99) on my local network, I want to reach a PLC (192.168.1.213) connected to the RUT240.
The computer is connected to the openvpn(synology) server and to the RUT240 also with its SIM card.
From the computer (10.8.0.10) I ping the RUT240 (10.8.0.6). I access the WEB interface.
But when I want to connect to the controller in 10.8.0.6:8080 it doesn’t work.
Do you have any idea about the problem?
I’ll walk you through the configuration.
The configurations look fine. Please, make sure that your PLC has a default gateway configured and is pointing towards the LAN IP address of the RUT device (I assume 192.168.1.1).
Also, you can try enabling masquerading for the LAN => WAN/VPN zone in the firewall settings to see if it helps.
Thank you, everything works very well!!!
