RUT240 lan clients no internet connection
Hi Forum,
i have a RUT240 and works very well till 3. august.
router seams to be hang up und must restart with power cycling.
now router is up and looks good running. but all lan, wlan, clients can not connect to internet.
doesn’t matter with wan or mobile lte outgoing.
any idea where to search. here is the ifconfig. can also send troubleshoot file.
need some ideas please :slight_smile:
root@Teltonika-RUT240:~# ifconfig
br-lan    Link encap:Ethernet  HWaddr 00:1E:42:XXXXXX
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fd22:f29XXXXXXXXXXX/60 Scope:Global
          inet6 addr: fe80::XXXXXXXXX/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:55127 errors:0 dropped:0 overruns:0 frame:0
          TX packets:18503 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:5910735 (5.6 MiB)  TX bytes:7352732 (7.0 MiB)
eth0      Link encap:Ethernet  HWaddr 00:1E:42:XXXX
          RX packets:55130 errors:0 dropped:2 overruns:0 frame:0
          RX bytes:6682707 (6.3 MiB)  TX bytes:7352732 (7.0 MiB)
          Interrupt:5
eth1      Link encap:Ethernet  HWaddr 00:1E:42:5XXXXX
          inet addr:192.168.200.13  Bcast:192.168.200.15  Mask:255.255.255.240
          inet6 addr: fe80::21e:42XXXXX/64 Scope:Link
          RX packets:12355 errors:0 dropped:507 overruns:0 frame:0
          TX packets:6854 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1464754 (1.3 MiB)  TX bytes:539083 (526.4 KiB)
          Interrupt:4
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:94636 errors:0 dropped:0 overruns:0 frame:0
          TX packets:94636 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:14711872 (14.0 MiB)  TX bytes:14711872 (14.0 MiB)
wwan0     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10.201.113.42  P-t-P:10.201.113.42  Mask:255.255.255.255
          inet6 addr: fe80::b9e9:eXXXXXX/64 Scope:Link
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:24534 errors:0 dropped:0 overruns:0 frame:0
          TX packets:54453 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3554853 (3.3 MiB)  TX bytes:12131850 (11.5 MiB)
Since you have received an IP address from your carrier, the issue could be one of the following:
  • No credit coverage - make sure the SIM works well in a mobile phone or any other device;
  • Missing/incorrect DNS server used - navigate to Network → Interfaces → General, edit the mob1s1a1 interface, and under Advanced settings tab, you will find a field to use Custom DNS servers. Try setting them to 8.8.8.8 and 1.1.1.1.
  • Mobile connection not established/signal issues - please post a screenshot of the Status → Network → Mobile page. Make sure to blur our any identifying information.
This will give me a better idea of what the issue could be.
Daumantas thanks for your fast reply. with WAN connection the clients wont also get internet
if i switch in failover settings mob1s1a1 as first, RMS connection works, but no client internet
if i switch in failover settings to WAN as first, RMS works not, and clients no internet
WAN connection is working with other switches or routers. so must be a RUT240 issue
It’s hard to say what could be causing the issue without having any more information. However, if you do not have a lot of configuration on the router, I’d simply recommend updating the device to the latest firmware without keeping the settings. This will perform a factory reset and resolve any issues related to the configuration.
