RUT240 how to whitelist IP adresses for connecting
Hi all,
how could I restrict connection to teltonika and devices connected to it, only from whitelist IP addresses in wan ?
Best wishes,
Devis
When creating a port forward, you can specify the addresses that you’d like to allow the connection from in the Source IP address field. Keep in mind, that only the external IP addresses should be present in this field, as mobile operators and ISPs often use NAT which changes the source IP address of the packets.
As for the WebUI access, the same can be done in Network → Firewall → Traffic rules, by editing the Enable_HTTP_WAN rule and specifying the source IP address.
Thank you, was looking from different point how it should work :slight_smile:
Best wishes
