RUT240 flash error
I need to repair my RUT240 from u-boot. I run httpd command and sloved from web service.
Great thanks.
If not already done, have you tried recovering your RUT240 using the Bootloader menu? Detailed instructions for accessing and utilizing the Bootloader menu can be found here: Bootloader Menu.
Additionally, could you clarify which httpd command you are running or provide more details about the issue you’re facing?
FYI, I logged in with ssh to my RUT240. I tried command “mtd -h” and it erased some part of my flash. So my router stucked at uboot. Then I connect to u-boot uart (ttl) and tried to recover. then I saw httpd command integrated to u-boot and run it. This helped me to connect from web-browser and flashed the firmware.bin thru web service. So I have deleted / edited my questions to thank for great u-boot “httpd” command. :slight_smile:
Thank you for the clarification and for sharing your recovery process.
If you have further questions or need assistance, feel free to reach out.
