How can I configure WAN as LAN? I need Mobile, LAN, WAN, WiFi to be connected over same subnet.
Here are some links which may help you:
https://wiki.teltonika-networks.com/view/Setting_up_WAN_as_LAN
https://wiki.teltonika-networks.com/view/RUTOS_relay_/_Wi-Fi_extender_/_repeater_/_bridge_configuration
However, are you sure you need the mobile interface to be bridged to LAN?
Make sure there is only one DHCP server, and all of the clients are in the same subnet with the same netmask.
If more information is needed, let me know.
I don’t have the option use port WAN as LAN
The WebUI needs to be in a basic mode. You can switch to it by clicking the mode button in the top-right corner:
