Здравствуйте, можно ли зайти на сайт 192.168.1.1 если забыл пароль но без сброса настроек? Или есть какой то конфигуратор на пк? И как можно сделать порт WLAN в LAN?
Since you have forgotten your current password, we will have to move to private conversation, to avoid accidentally leaking private information. We will investigate whether it is possible to recover your password. We have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 15564.
Could you elaborate more on WLAN to LAN question?
Vilius.
Я хочу подключить в WLAN порт кабель который будет работать через LAN
By WLAN do you mean Wireless LAN or WAN as in Wide Area Network?
Vilius.
локальную, чтобы по порту WLAN работало устройство в локальной сети
Just to clarify - WLAN stands for “Wireless LAN” a.k.a something that doesn’t really have a physical port, that’s why I’m quite unsure of what you’re trying to ask exactly.
I would assume you want to turn the WAN port, which is supposed to be the port that allows your device to take internet from other devices into a LAN port, would that be the correct assumption for your case?
More so, regarding the lost password, I’ve already sent you a form to fill out, you should be able to find it within your inbox.
Vilius.
Да, извините. Из WAN сделать его LAN
In that case, please follow this configuration example:
However, you will need to log into the device to change these settings, therefore, I kindly remind you that you can find the details for a private session in your email inbox. For security reasons we can proceed there.
Vilius.
а есть инструкция на старом интерфейсе?
Here is a configuration example for the legacy interface:
Vilius
