Hy,
we have a RUT200 router that worked for about half a year. But now it doesn’t turn on, only the power led blinks (~1HZ).
What could be the cause of the problem?
Thanks in advance for your answer.
Could you please try to update the device firmware to the latest one (you can find it here) via the bootloader menu as described in this guide?
Please let me know if it helps to resolve the issue.
Hy,
meanwhile we found an another power supply adapter for test, and it works with it now, so there is something wrong with the adapter.
Thank you for the quick reply.
Good to hear the issue is resolved now!
Please don’t hesitate to reach out on the forum if you have any further questions or concerns.
