RUT200 OpenVPN lan clients not accessible from server
Hi!
Few days tried to settle out the problem…
I have an openvpn server network (10.183.240.0/27) with server (.1 ) and clients (.2 - .5) with subnets (10.183.240.32/29 - .56/29). Subnerts are not communicating with each other.
Problem started when i changed LAN ip and openvpn connection (cert & ip updated), i’m not able to connect clients in subnet from server network. Yep, everything worked well before…
Inside LANs, clients are accessible and are working normally (new IP’s obtained from rut200’s dhcp).
I can ping rut200 from openvpn network, as well as i can ping server from router and from subnets, but ping does not work from server to clients.
I installed tcpdump and i can see (lan interface) a ping request to client but not a response from client.
I’ve tried to add static routes, played with fw rules but nothing helped. I think i have read whole wiki as well as forum, checked almost all i can imagine, but no.
What you suppose to check or fix?
Hi…
So…
You have…
/27 |10.183.240.0|10.183.240.1 - 10.183.240.30|10.183.240.31|
/29 10.183.240.32 10.183.240.33 - 10.183.240.38 10.183.240.39
and
/29 10.183.240.56 10.183.240.57 - 10.183.240.62 10.183.240.63
Who is the gateway (ip address) for your first and second /29 network?
Who is the gateway (ip address) for you " server " network /27?
Server network gateway is 10.183.240.1, which is also binded to public ip.
Gateways for client subnets are configured to be rut200’s ip in SUBNET, for example 10.183.240.56 is gw for devices in 10.183.240.56/29. From server network, 10.183.240.5 is assigned to this same router. Both of those IPs replies to ping and rut200 admin is available in both of those IPs.
And one more thing, wired wan is not available, only mobile connection is in use.
Hi… x.x.x.56 cannot be your gateway… is the network of it… the lan ip should be bettwen x.x.x.57 to x.x.x.62…
Please… Can you draw your network? simple? with ip address / netmask in each point?
Thank you.
Basic mistake, hit me.
Changed IP, nothing happened.
Ping request is coming in but still no response.
Ping from rut200 (ssh) works fine.
[edit] Yes, reply to ping from any network is enabled from client device.
one step at time… :sunglasses:
so… you have RUT200… two LANs at the device. Because you change WAN to LAN. I gues… I draw will help…
But… you have three networks… one /27 and two /29
Sure… you can use secondary ip address at the same lan interface… no worries.
but… you cannot have dhcp server without VLAN in this interface… Do you have L2 Switch?
To make this work…
you need to have the first host ip at the network in the lan of your device (rut200)
sample.
server farm 10.183.240.1/27 (interface??)
lan(1) 10.183.240.33/29
lan(2) 10.183.240.57/29
all the connected ip devices, will have the lan ip address of that network in RUT200 as their gateway?
This will happen with the packet
  • x.x.x.2 ping x.x.x.60
  • x.x.x.2 wil send to x.x.x.1; because don’t find x.x.x.60
  • x.x.x.1 will redirect your packet to lan interface x.x.x.57
  • x.x.x.60 will receive the packet… because it don’t know where it is coming from… it will back to x.x.x.57
I am try to keep it a simple explanation…
No, i have several routers, each with own openvpn connection.
I’ll try to draw tat image…
Do you know… ovpn do a NAT!!! okay?
ok, but the question is what was changed because it worked before… I’ve never touched any nat -specific settings.
Thx Marcello pointig me to right direction. Had to set lan => openvpn MASQUERADING on.
Now routing is working as excepted, thank you for your time!
