RUT200 mobile data disconnected after FW update
Since FW update, my RUT200 device cannot connect to mobile data.
I can not upload the troubleshooting log file (new user warning)., so I have uploaded it to GDrive
Troubleshooting Log
Here is relevant info which I think might be of interest.
[Firmware version]
RUT2M_R_00.07.08
Tue Aug  6 14:52:31 2024 daemon.notice netifd: mob1s1a1 (13075): Stopping network mob1s1a1
Tue Aug  6 14:52:31 2024 daemon.notice netifd: mob1s1a1 (13075): {
Tue Aug  6 14:52:31 2024 daemon.notice netifd: mob1s1a1 (13075): 	"status_id": 0,
Tue Aug  6 14:52:31 2024 daemon.notice netifd: mob1s1a1 (13075): 	"status": "OK"
Tue Aug  6 14:52:31 2024 daemon.notice netifd: mob1s1a1 (13075): }
Tue Aug  6 14:52:31 2024 daemon.notice netifd: mob1s1a1 (13075): Command failed: Permission denied
Tue Aug  6 14:52:31 2024 daemon.notice netifd: Interface 'mob1s1a1' is now down
Tue Aug  6 14:52:31 2024 daemon.notice netifd: Interface 'mob1s1a1' is setting up now
Tue Aug  6 14:52:31 2024 daemon.notice netifd: Interface 'mob1s1a1_6' is now down
Tue Aug  6 14:52:31 2024 daemon.notice netifd: Interface 'mob1s1a1_6' is disabled
Tue Aug  6 14:52:31 2024 daemon.notice netifd: Interface 'mob1s1a1_6' has link connectivity loss
Tue Aug  6 14:52:33 2024 daemon.notice netifd: mob1s1a1 (13110): wwan[13110] Using wwan usb device on bus 1-1
Tue Aug  6 14:52:33 2024 daemon.notice netifd: mob1s1a1 (13110): wwan[13110] Using proto:cdc_ether device:usb0 iface:usb0 desc:Quectel EC200A
Tue Aug  6 14:52:35 2024 daemon.notice netifd: mob1s1a1 (13110): Connection setup for mob1s1a1 starting!
Tue Aug  6 14:52:35 2024 daemon.notice netifd: mob1s1a1 (13110): Activating PDP CID1!
Tue Aug  6 14:52:35 2024 daemon.notice netifd: mob1s1a1 (13110): Starting setup data call!
Tue Aug  6 14:52:36 2024 daemon.notice netifd: mob1s1a1 (13110): Setting MTU: 1500 on usb0
Tue Aug  6 14:52:36 2024 daemon.notice netifd: Interface 'mob1s1a1' is now up
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using nameserver 8.8.8.8#53
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using nameserver 192.168.1.1#53
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using only locally-known addresses for test
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using only locally-known addresses for onion
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using only locally-known addresses for localhost
Tue Aug  6 14:52:36 2024 daemon.notice netifd: Network device 'usb0' link is up
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using only locally-known addresses for invalid
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using only locally-known addresses for bind
Tue Aug  6 14:52:36 2024 daemon.info dnsmasq[22170]: using only locally-known addresses for lan
Tue Aug  6 14:52:36 2024 daemon.notice netifd: mob1s1a1 (13110): Setting up usb0 V6 DHCP
Tue Aug  6 14:52:36 2024 daemon.notice netifd: Interface 'mob1s1a1_6' is enabled
Tue Aug  6 14:52:36 2024 daemon.notice netifd: Interface 'mob1s1a1_6' has link connectivity
Tue Aug  6 14:52:36 2024 daemon.notice netifd: Interface 'mob1s1a1_6' is setting up now
Tue Aug  6 14:52:36 2024 daemon.notice netifd: mob1s1a1 (13324): Starting connection tracker for usb0!
Tue Aug  6 14:52:36 2024 daemon.err odhcp6c[13331]: Failed to send RS (Address not available)
Tue Aug  6 14:52:36 2024 daemon.notice odhcp6c[13331]: (re)starting transaction on usb0
Tue Aug  6 14:52:36 2024 daemon.info odhcp6c[13331]: Interface usb0 sending router solicitation message
Tue Aug  6 14:52:37 2024 daemon.notice odhcp6c[13331]: Starting SOLICIT transaction (timeout 4294967295s, max rc 0)
Tue Aug  6 14:52:37 2024 daemon.err odhcp6c[13331]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
Tue Aug  6 14:52:50 2024 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue Aug  6 14:52:50 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Tue Aug  6 14:52:51 2024 daemon.notice netifd: mob1s1a1 (13413): Stopping network mob1s1a1
Tue Aug  6 14:52:51 2024 daemon.notice netifd: mob1s1a1 (13413): {
Tue Aug  6 14:52:51 2024 daemon.notice netifd: mob1s1a1 (13413): 	"status_id": 0,
Tue Aug  6 14:52:51 2024 daemon.notice netifd: mob1s1a1 (13413): 	"status": "OK"
Tue Aug  6 14:52:51 2024 daemon.notice netifd: mob1s1a1 (13413): }
Tue Aug  6 14:52:52 2024 daemon.notice netifd: mob1s1a1 (13413): Command failed: Permission denied
Tue Aug  6 14:52:52 2024 daemon.notice netifd: Interface 'mob1s1a1' is now down
Please help me solve this issue.
Regards.
-Asit
Hi asitjain,
May I know which firmware your RUT200 is running? I would suggest you to upgrade your device to 7.08.2 as we have recently released this version with a few system fixes.
Let me know if this helps.
The firmware version was RUT2M_R_00.07.08. After 3 tries, I was able to update it to latest version:
But the issue is same even after the update:
Please help.
May I know if you have a different SIM to test? I have devices here running on 7.08.2 FW with working mobile connectivity.
I would suggest you to proceed with Modem upgrade through WebUI. Go to System → Firmware → Firmware Type: Modem.
Before proceeding, please note of the following:
  1. Do not power off the device while upgrade is ongoing.
  2. Remove the SIM and have a Wired WAN source instead to have a more stable connectivity.
  3. Do not remove LAN cables while upgrade is ongoing.
Thanks for your quick reply.
I can not update the modem firmware as it says Modem firmware update is only available using mobile connection:
When I press the update button, it says:
Please suggest further steps.
I would advise you contacting us via HelpDesk, if you do not have access to it, then contact your Sales Manager via which you have bought the device or if you have bought through a vendor - Contact your vendor for further assistance with the RMA procedure. Here you can find more information about RMA procedure: RMA - Teltonika Networks Wiki
Can I go back to the earlier firmware version which was working?
Absolutely. While troubleshooting is ongoing, you can revert to previous working FW. Before downgrading, can you check your IPv6 settings (WAN-> mob1s1a1 → IPv6 Settings). Also, kindly check Internet Status (Network → Internet Status)
