RUT200 Firewall Zone
I accidently changed the lan firewall zone to unspecified and now I am unable to reach the webUI.
I am unable to login via putty and I only have access to this remotely.
Is there any way to change this back without factory resetting the device?
Could you please provide more details about the specific setting you changed?
https://wiki.teltonika-networks.com/view/RUT200_LAN#Firewall_settings
In the above link, I changed the firewall settings from lan to unspecified.
How do you access the device remotely? If you have direct access from the WAN or through RMS, you can use the device’s public IP address (e.g., 84.x.x.x). Otherwise, it looks like the device will need to be reset to restore access.
