RUT140 - How do I Reassign Management Interface
I have a RUT140 which has a management interface that is by default assigned to VLAN1. Is there a way to reassign the management interface to a different VLAN?
Thank you in advance,
PS
Good afternoon,
To achieve your desired configuration, here is a guide :
  1. Firstly, please go to to Network → VLAN → Port Based.
Click Add to create a new VLAN.
Assign a new VLAN ID different from the default VLAN 1.
Select the LAN port or ports you want to use for this VLAN and set them as “Tagged” or “Untagged” as per your network needs.
Disable or turn off the ports in VLAN 1 that you want to remove from management access.
Save and apply the settings.
  1. Then you will need to create a New LAN Interface for the VLAN
Go to Network → LAN.
Click Add to create a new LAN interface.
For the new interface, select the VLAN device you created (for example eth0.10 if VLAN ID is 10) as the physical interface.
Assign an appropriate IP subnet to this interface distinct from VLAN 1 (for example 192.168.10.1/24).
Enable DHCP server on this LAN interface if needed for devices on this VLAN.
Save and apply the changes.
  1. Then you will need to adjust the VLAN1 interface
Edit the default LAN interface assigned to VLAN 1.
Change port assignments or disable DHCP if VLAN 1 is no longer managing devices
This prevents conflict and limits management access to the new VLAN
Arturas
