RUT 95X firmware 7.06.3 modbus
Hello, I have a RUT955 with firmware 7.6.0 and I was using the Modbus TCP over Serial Gateway function without any issues to read a RS485 device on port 506. Now, following the update, I am unable to use this function on many modems. How can I solve this?
Gratings Samuele
Could you please check this forum post here and confirm if you are having the same issue?
Specifically, that it works on v7.06.0 and v7.06.1, but not on v7.06.3?
Could you please navigate to System → Maintenance → Troubleshoot → View System Logs, and share those logs here?
