Rut 956 stuck on startup
hi, i have a rut 956 i have a problem with booting, it stays stuck on booting. is it possible to flash with usb or rs232
thanks
Thank you for reaching out.
Could you confirm if any of the LEDs light up during the boot process? Additionally, if possible, please try using a different power adapter or power supply to ensure the issue is not related to power.
If the issue persists, I recommend attempting to access the device’s Bootloader menu and flashing the firmware through it. You can find detailed instructions for this process here: Bootloader Menu
If none of these steps resolve the issue, please contact your sales manager or reseller to proceed with an RMA, provided the device is still under warranty.
Let me know if you need further assistance.
