Multiple RS-232 to USB converters are connected to USB HUB
and the USB hub is connected to the USB port of RUT-956.
In DLMS Connection configuration will i be able to select connection
type as USB RS232 interface and further specify the specific serial device
corresponding to the USB serial converter ? ( thereby connecting multiple RS-232 DLMS meters
to the RUT-956 gateway )
Specifically i mean if i select connection type as “USB RS232 interface” will there be another drop-down which allows me to select the serial device ( Like /dev/serial5 )
Correction of my previous statements, I was completely wrong. Here’s what the R&D had to say:
You can connect multiple devices via a USB hub. They should all be visible under different names, and our DLMS service should handle all of them.
If you were to use an RS485 connection instead, it does provide more capabilities, when it comes to the client count; however, we have such limits in our WebUI: 10 connections, 30 physical devices, 10 groups with 20 values.
Does the imposed limit " 10 connections, 30 physical devices, 10 groups with 20 values." applicable to RS-485 case only . Are these limits present for RS-232 ? Specifically
