RUT 956 MQTT Bridge
I’m looking for a way to add or remove a MQTT Bridge via an API.
My situation:
Un-encrypted MQTT from local device (it does not support tls) to the Router as a Broker.
Router to Cloud Bridge this will always be there.
Router to Local Bridge (Connected Via the Wired WAN) this is the one I want to add / Remove based on the assigned site.
Another Option would be if possible to have both Un-encrypted Un-authenticated MQTT (LAN Only) and Encrypted Authenticated MQTT connections (LAN & WAN) then the local server can connect using the WAN port securely)
Thanks for your help,
You can achieve this on a single broker by enabling the “Use TLS/SSL” option and disabling the “Require certificate” option.
