RUT-955 MIB - mSINR incorrect type
Using snmpget to read the mSINR.1 variable goes not work correctly with the MIB downloaded from the link in the web screen in the device.
snmpget -v2c -c public Teltonika-RUT955.com. -m TELTONIKA-MIB mSINR.1
Changing from type DisplayString (SIZE (0…255)) to type INTEGER fixes the issue.
TELTONIKA-MIB::mSINR.1 = INTEGER: 0
Possibly review published MIB against embedded code in RUT0955?
TELTONIKA-MIB::fwVersion.0 = STRING: RUT9_R_00.07.06.10
(more)
snmpwalk -v2c -c public Teltonika-RUT955.com. -m TELTONIKA-MIB 1.3.6.1.4.1.48690.3 | grep Wrong
TELTONIKA-MIB::numSatellites.0 = Wrong Type (should be INTEGER): STRING: “10”
peter@ellingham:~> snmpwalk -v2c -c public Teltonika-RUT955.com. -m TELTONIKA-MIB 1.3.6.1.4.1.48690 | grep Wrong
TELTONIKA-MIB::mRSRP.1 = Wrong Type (should be OCTET STRING): INTEGER: -108
TELTONIKA-MIB::mRSRQ.1 = Wrong Type (should be OCTET STRING): INTEGER: -14
TELTONIKA-MIB::mSent.1 = Wrong Type (should be Counter64): INTEGER: -2055739710
TELTONIKA-MIB::mReceived.1 = Wrong Type (should be Counter64): INTEGER: -831272276
TELTONIKA-MIB::mSentToday.1 = Wrong Type (should be Counter64): INTEGER: 3749400
TELTONIKA-MIB::mReceivedToday.1 = Wrong Type (should be Counter64): INTEGER: 1806385
TELTONIKA-MIB::mSentCurrentWeek.1 = Wrong Type (should be Counter64): INTEGER: 1442300267
TELTONIKA-MIB::mReceivedCurrentWeek.1 = Wrong Type (should be Counter64): INTEGER: -1572765266
TELTONIKA-MIB::mSentCurrentMonth.1 = Wrong Type (should be Counter64): INTEGER: 783932588
TELTONIKA-MIB::mReceivedCurrentMonth.1 = Wrong Type (should be Counter64): INTEGER: -1868789537
TELTONIKA-MIB::hsSessionCount.0 = Wrong Type (should be Counter64): INTEGER: 0
