RUT 241 No Signal with Omnisim By Kore
Hallo all, I have a problem on RUT 241 with Omnisim by KORE, The signal not available, but apn set up is done, but still problem, any solved for this case??
Please ensure that the antennas are properly connected to your RUT241 at a 90-degree angle.
Additionally, are there any logs indicating that the mobile connection is established and that your device is connected to the operator? Could you also share a screenshot showing that no signal is detected?
Have you tried rebooting the device or performing a factory reset? If not, please try these steps as well.
