RUT 240 io Juggler call action
Hi ,
Could anyone confirm whether the latest firmware of the RUT240 includes the Call Action feature within the IO Juggler? I’m currently using an RUT906, which supports this functionality, but I’m uncertain if the RUT240 offers the same. I’d appreciate clarification before proceeding with the purchase.
Afthab
Could you please clarify the intended use case for the device and specify which actions you need it to support?
You may also find this article helpful, as it outlines the actions supported on the RUT240:
I need to make a call to a number whenever the input goes high, in rut 906 its straight forward with latest firmware. I want to confirm this feature available in RUT24
The “make a call” action feature is not available on the RUT240. However, it is supported on the RUT241.
