RUT 240 & 241 Not able to connect to EE network
I have both a RUT240 and a new RUT241 running the latest respective firmware but neither of them are able to connect to the EE network. I have swapped between AutoAPN and manual with the correct settings for EE and neither of them will work. I have switched from IPv4 to IPv6 and back and still will not work. I can place the SIM in a RUT955 and it works fine. I can put a different carrier cell card into it and it works.
To determine the root cause of this issue, we’ll need the troubleshoot file. Since it contains private information, we’ll handle it on a separate platform. Instructions for accessing it have been sent to the email you registered for this forum.
Marijus
