Router disconnect to internet
The router disconnects to the internet when this log appears, this log appears when the router is up for 20 hours, what caused this log?
Device: RUT955
Firmware version: RUT9_R_00.07.04.4
[7/28/2023, 8:06:05 AM] hostapd: nl80211: nl80211_recv_beacons->nl_recvmsgs failed: -5
[7/28/2023, 8:04:59 AM] gsmd[2215]: [ubus_call_hotplug:262] error: [MODEM_UBUS] Failed to invoke ubus hotplug.d gsm method for `1-1.4 [2c7c:0125]` modem!
[7/28/2023, 8:04:59 AM] hostapd: nl80211: nl80211_recv_beacons->nl_recvmsgs failed: -5
[7/28/2023, 8:04:19 AM] hostapd: nl80211: nl80211_recv_beacons->nl_recvmsgs failed: -5
Does it reconnect after some time? What do you do to restore the connection?
Also, could you please try flashing the firmware via the bootloader procedure as described here?
I will try to flashing the firmware via the bootloader
I want to ask about SNMP, how do change type OctetString to Integer in Teltonika
