RMS VPN - Web Page not loading
Hi everyone,
I’m using Teltonika RMS with a VPN Hub to remotely access the web interface of a BMS controller behind a Teltonika router.
I’ve successfully configured this many times before with different devices, following the usual YouTube setup guide.
Recently, however, I’m having an issue where I can connect to the VPN and successfully ping the BMS controller, but the webpage either loads partially or gets stuck and never fully loads.
My current setup includes:
  • Teltonika RUT241: Firmware 00.07.24.7
  • Another RUT241 installation: Firmware 00.07.23.7
  • Working Teltonika RUT200 installation: Firmware 00.07.24.3
Interestingly, I can still access the same type of BMS controller webpage through the RUT200 without any issues.
The VPN configuration is essentially the same across the installations. Normally, once I can ping the controller through RMS VPN, the webpage loads without any problems.
Has anyone experienced similar issues with the RUT241, particularly with the newer firmware versions? I’m wondering whether this could be firmware-related or if there is another setting I’m overlooking.
Any advice would be appreciated.
