Hi Everyone,
We run an RMS VPN Hub with two RUT241 routers connecting lab instruments to our on-prem test servers. Our free company data is almost used up, and the hub’s Session view shows the same traffic counted against both routers.
Could you please confirm:
- Is VPN Hub traffic charged per router, so we would need a 150 GB Connection Data Pack on each router?
- If both routers have a pack, does the hub still draw on company data or credits for anything?
- What is the best option for about 20 GB a month of combined hub traffic: credits or data packs?
Thanks,
Nilaksh Chib
Thank you for reaching out.
1. Do you need a data pack on each router?
Yes, if you want both routers to use pack data instead of company data. Each 150 GB Connection Data Pack is assigned to one device and lasts until exhausted or for 10 years. Alternatively, both routers can use shared company data.
Teltonika Wiki – Connection data packs.
2. Will the hub still consume company data or credits?
With both routers on active, non-exhausted packs, their VPN traffic uses pack data first. If VPN hub has a mix of devices that are using company data and pack data - users will default to using company data. RMS Management licensing remains separate, connection packs do not replace management credits or management packs.
3. Which option suits 20 GB/month?
For 20Gb/month company data requires 10 credits/month, since one credit converts to 2 GB. A 150 GB pack therefore equals 75 credits’ worth of data. Compare these options to see which one is more suitable for you.
T.
