Hi all.
I got a RUT300 router configured on lan side in 192.168.240.0/28 network (RUT300 ip 192.168.240.1) with some connected hosts.
On the wan side of RUT300 there’s a dynamic IP on 192.168.2.0/24 private network.
Wan Gateway for RUT300 is 192.168.2.250/24 (Network Switch)
There’s another segment beetwen switch and company firewall.
VPN address pool is in 192.168.255.0/24 network that’s Teltonika RMS default.
While connecting from remote location I can join VPN connection but I can ping the only VPN interface of the RUT300, usually 192.168.255.1.
I cannott absolutely ping any host in RUT300 Lan or the RUT300 lan interface.
I added static routes in configuration for every ip behind RUT300
192.168.240.1
255.255.255.255
RUT300
than
…2
.,…3
etc…
There’s a PC on lan side with RDP enabled network card configuration is
IP Add 192.168.240.9/28
GW 192.168.240.1 (RUT300 Lan Ip Add)
DNS 192.168.240.1
DNS2 8.8.8.8
I’cant ping or connect by RDP to this PC
I also configured a policy on our firewall to accept packet from germany VPN address on port range 30000-39999.
No way…
Should I have to open some ports on company firewall?
Some ideas?
Thank you
