RMS Tasks - Acceptable Return Codes
Hello just wanted to know if you have any updates regarding this issue?
EDIT:
To add to this, I updated to latest firmware (RUT9M_R_00.07.06.1 ) and tried some tasks again.
What seems to have changed is if I simply do this in the task:
exit 1
echo "should not be printed"
then it behaves correctly, No message is seen in the log, the task is marked as failed and Task 2 in the same Task Group is not executed.
But if I do this:
echo "this must be printed"
exit 1
then it behaves incorrectly; I see only this must be printed in the output but the Task is marked as successful and subsequent tasks in the Task Group are executed.
EDIT 2
It seems to be that the failure needs to happen first. This fails as it should
set -e
cp non_existing_source non_existing_destination
echo "should not print"
and this fails as it should
exit 1
But this is marked as successful (“should not print” does not print):
set -e
echo "should print"
echo
The RnD team did not include the fix in version 7.6 due to higher priority tasks. However, the fix should be included in future firmware releases.
