My router (connected to fiber with no SIM) has its RMS monthly pack expired. I bought a new 5Y pack for it.
The router didn’t connect back to RMS since 8 days.
I have verified that the router has the pack:
Paid Management pack 5y. → valid until 2030-06-09 10:36:48
I do want to note that these steps mainly cover information in the device’s WEBUI, so you would need access to it, whether its remote, or local.
As the device has no Sim, sending a text message is not an option either.
I wanted you to check whether the RMS service is toggled on, in company details, whether you receive some sort of an error message next to the device.
If the above advised steps do not work, you do not see any error, service is on, and the rest of the troubleshooting has been done, as in the thread provided, then it seems that everything from the RMS side is ok, and you would need to check the device itself, whether locally or remotely, if you have a connection set up.
Yes it is toggled on. I have several other routers and RMS is working perfectly.
When I changed the pack to 5years, it worked on 1 or 2 routers but 3 or 4 are missing.
