I checked the wiki but I couldn’t find where its documented how often a router will attempt to connect to RMS after its been offline. Does a power cycle reset the connection attempt backoff schedule? This is particularly relevant to us as we use cellular routers like the RUT956.
I found this picture in another post. I guess the tooltip is the documentation. Just to be clear, if the router does not have an internet connection it will never go into standby mode?
Also, the power cycle reset of standby mode could be important as I pre-configure the routers and connect them to RMS before shipping. In some cases it could be several weeks before they are installed and it would be nice if they connected to RMS right away instead of 6 hours later. Although in this case I’m not sure the power off time counts as a disconnection.
Hello @doug-mistall,
Thank you for reaching out!
When the devices are turned on again after some time, they should reconnect normally within 2 to 5 minutes, provided that an Internet connection is available. Also, if a device has never had an internet connection, it won’t connect to the RMS platform at all, meaning it will not enter Standby mode.
If you ever need to manually force a reconnection, you can click Reconnect in the WebUI under Services > Cloud Solutions > RMS or send an SMS command to the router:<router_password> rms_connect(if the SIM card supports sending and receiving messages).
If you have any other questions, please don’t hesitate to reach out!
Martyna
That was great info. Normally we provision and test the routers before shipping out and I connect them to RMS. But if for some reason I have to send a brand new router directly to a site it would seem that the SMS reconnect method would work. I’ll test it out of course. Thanks.
I took a look at RMS and can’t seem to find where I can send an SMS message to the router.
Glad I could help! Just to confirm, RMS doesn’t have a feature to send outbound SMS messages directly to the router. To send an SMS command (like rms_connect), you’ll need to text the router’s SIM phone number directly from your mobile phone, or an external SMS gateway.
If you run into any other questions, please let us know!
Martyna
Okay got it. Would be convenient feature to have in the RMS dashboard.
Thank you for the suggestion! I’ll pass this along to our R&D team for further consideration.
Let me know if anything else comes up or if you have any questions!
Martyna
