RMS problem RUTX50
Having trouble accessing WEBUI. Generates fine access link, but I end up only getting a connection unsuccessfulful after long attempts to connect. RUTX50. Are there currently problems with RMS ?
There don’t seem to be any issues with RMS.
Could you clarify if any configuration settings have been changed?
It’s also possible that you have blocked yourself on accident by entering the incorrect password too many times. To check this, connect to the device using RMS Connect or RMS VPN Hubs, log into the WebUI, navigate to System → Administration → Access Control, and in the Security tab remove any entries from Login Attempts section.
Let me know if that helps.
Now it works. Thanks for your suggestions. Many thanks for the help. You learn every day :+1:
